1999 Ram 4x4 2500 problems
Old Sep 10, 2013 | 08:10 PM
lennoxsilver's Avatar
lennoxsilver
Question 1999 Ram 4x4 2500 problems
Airbag light comes on and off, but mostly on. Brake light on all the time. ABS light on all the time. Check engine light is on all the time. Speedometer only works when I get up to about 40mpg. Couple other gauges sometimes work and sometimes not. Anyone with any ideas? Thanks
Old Sep 10, 2013 | 08:50 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Will move you now.
Old Sep 11, 2013 | 09:27 AM
clipper77's Avatar
clipper77
Have you hooked it up to a scanner to see if there are any stored codes?
If ABS/ brake lights are on, verify that there is fluid in the MC.
Check voltage at the battery, check connections to alternator.
What have you done to troubleshoot so far? Anything?
It's not much, but it's a start...
Old Sep 11, 2013 | 10:57 AM
Start by replacing the rear wheel speed sensor. That should solve a few of the issues.
Old Sep 11, 2013 | 12:48 PM
lennoxsilver
P1762...P0500....P0138
I replaced the bank 1 02 sensor. I replaced the speed sensor in transfer case..Waiting for parts for governor pressure sensor.
Old Sep 11, 2013 | 12:49 PM
lennoxsilver
ok....I try that next. Thanks
