AC Question
So driving with AC on, while under medium to heavy accelerating, the AC stops blowing cold air. I can hear the fan, but when you put your hand on the vents, no air comes out. as soon as i let my foot off the gas, AC resumes nice and cold.
is that normal on these trucks? I should also say that I hear like a little door closing anytime i let off the gas, sounds like a trap door closing. weird?
well will you look at that... took some pics of how all the vaccum lines are set up. does this look right?
This below pic: the V shaped valve goes directly into the manifold, and then it goes into the T.
then the T is connected to another T.
do those look alright? I think I already found where my leak is. The Cruise control line just doesn't terminate anywhere. fixing this should get rid of the wild vents right? I already bought the check valves, so I will replace those just for the hell of it.
Yea, it does look right, did you look for the "wild vents" thread as stated? Replace the two check valves. And repair that line to the CC servo under battery, and that should fix your problem.
Trending Topics
it still does it though, to some extent but its not as bad as before. so I can live with it. the wife has put an end to fixing things... for now.
