Long hard starting issue
Old Sep 15, 2013 | 02:04 PM
97ramrod1500's Avatar
97ramrod1500
Originally Posted by zman17
Cycling the key does squat if the regulator is that bad, fuel pump time.
Six. (or eight...)
Better to drop the tank though.
I'm thinking it'll be easier to raise the bed since ill be doing this in my shop at home and I just filled the tank. I don't feel like siphoning it out.
Old Sep 15, 2013 | 05:28 PM
Fuel pumps only fail when the tank is full.
Yeah, I understand that one.
Old Sep 15, 2013 | 06:41 PM
97ramrod1500
It wouldn't work any other way. I was figuring it was the pump but wanted second opinions before I dumped $200 into the truck. Last winter the fuel gauge stopped working for a while then started again so I kinda forgot about it.
Thanks everyone for the replies!
zman17's Avatar
zman17
Retired Moderator - RIP
Good luck figuring out all the wires that get screwed up after lifting the bed. Spend 10 minutes and siphon the tank.......
Old Feb 28, 2014 | 02:31 PM
tvmbama31's Avatar
tvmbama31
Default Dodge 5.7 Hemi Have to press Gas Pedal to Crank
I have a 2005 Dodge 1500 5.7 liter hemi that I have to press the gas pedal in order to get it to crank. I have replaced spark plugs, spark plug wires, egr, purge, fuel filter and fuel pump, cleaned out throttle body, and it stills continues to not crank unless i press the gas pedal. Has anyone had trouble like this before and what could be the cause of it. My CEL is on and it coded out EGR again, but I just replaced it. Thanks for the help.
Old Feb 28, 2014 | 03:03 PM
P1NKST@FF's Avatar
P1NKST@FF
That's a different truck than what is discussed in this forum altogether, you will probably have better luck in the third gen forum
