Wierd shutter when I turn a corner
Old Sep 18, 2013 | 02:48 PM
Dvoeltz's Avatar
Dvoeltz
Default Wierd shutter when I turn a corner
I had a 1999 2500 Diesel that never did this. Would still have that truck had it not been totaled out as a result of a texting driver. Anyway, we survived T-Boning the idiot who pulled out in front of us and I ended up purchasing a 2001 diesel of the same configuration (4WD, extended cab). It does have wider tires than the 1999 had.
Things are fine as I roll down the highway. However, when I make a slow turn as in turning from one road to another, I feel a weird shuttering in the drive train, much as what you feel when the truck is engaged in 4 wheel drive.
I have had it to a shop twice and my local mechanic can't find anything. I suppose I could take it to the stealership and have them look it over but thought I would check here first if any of my fellow members would have any ideas.
Thanks in advance.
Dave in Pierre, SD
Old Sep 18, 2013 | 03:49 PM
merc225hp's Avatar
merc225hp
Improper oil in the rear end for a lsd will cause this. Pull the diff cover look for damage, metal bits, if none found refill with good oil and the lsd oil modifier.
Old Sep 18, 2013 | 03:51 PM
+1 if it has LSD and someone changed the fluid and did not put the correct additive in it.
Old Sep 18, 2013 | 04:58 PM
VARam1500's Avatar
VARam1500
If you feel it telegraphing in the steering, replace the axle u-joints. My experience is that they get cranky between 50-75k.
Old Sep 19, 2013 | 07:48 AM
Dvoeltz's Avatar
Dvoeltz
How do I determine if my differential is LSD? Since I didn't have time, I did have the fluids replaced by my mechanic when I purchased it since I didn't know when they were last replaced. And axle U-Joints were my first thoughts when I felt this. The truck has 84,000 miles so it could be both things. Something for me to do some free weekend.
Old Sep 19, 2013 | 10:00 AM
Pull the cover and look. 'Nother option would be to get a build sheet from chrysler. (link in faq section) That will tell you whether your truck 'should' have on or not.
Old Sep 21, 2013 | 01:03 AM
ReadRam's Avatar
ReadRam
Pull the cover off the diff. You will probably find pieces of clutch packs and little clip that hold them together.
