Bad gas Mileage no power
Old Sep 18, 2013 | 09:39 PM
KenMckinley's Avatar
KenMckinley
Default Bad gas Mileage no power
Some one help me figure this out. I have a 2001 dodge ram 1500 318 nv3500 4x4 120,000 miles. I only get 10 to 12 mpg on the highway and have what seems like a loss of power and find myself downshifting for even small hills. The truck idles fine but around 1400 to 1600 Rpms sometimes will lose a little power and surge back slightly. Any pointers?
Old Sep 18, 2013 | 09:55 PM
stewie01's Avatar
stewie01
This belongs in the Tech Section....A mod can move it for you.
Probably plenum, cat, and O2 sensors...
Compression test first probably not a bad idea either....
Old Sep 26, 2013 | 08:44 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
A complete tune up with new plugs and distributor cap isn't a bad idea either. Running sea foam through it and cleaning the throttle body might help. Checking the air filter and air pressure in the tires would be easy to do
Old Sep 26, 2013 | 08:52 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Get the catalytic converter pressure checked at a muffler shop. You're describing symptoms of a clogged cat.
Old Sep 26, 2013 | 09:09 AM
Ham Bone's Avatar
Ham Bone
You could also whack it with a rubber hammer and see if you hear any rattling.
Also can take out front O2 sensor and see if it drives any better
Old Sep 26, 2013 | 10:36 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
And it sounds like you IAC valve is trying to go south.
Old Sep 26, 2013 | 11:13 AM
Ramman18's Avatar
Ramman18
Idle should be 550rpm warm. Massive vacuum leak so I would check plenum, hoses, etc. When my cat went it never lost power, just rattled at stoplights.
Old Sep 26, 2013 | 11:23 AM
dodge dude94
Same here. A chunk of catalyst fell apart and bounced around.
Granted, my exhaust guy pounding on the exhaust pipe while installing my muffler didn't help either. But it gave me the reason to swap the cat out.
