1995 Ram 5.2 no o/d
Old Sep 19, 2013 | 09:04 PM
felixbot's Avatar
felixbot
Default 1995 Ram 5.2 no o/d
My 95 Ram will not shift into overdrive. The light on the swit h does not illuminate. It is like the o/d is turned off. I believe that "on" is the default position for the switch, so if i turned the truck off and back on, the o/d should be on. I have heard that there is an o/d solenoid somewhere on the trans. and that could be the problem. Any suggestions?
Thanks! Joe
Old Sep 19, 2013 | 09:35 PM
Arde's Avatar
Arde
The OD is on by default, light off. When the light is on, OD is off.
Download the factory service manual in the DIY/FAQ section, it has the info. you need to service the OD unit.
