OEM Crank Position Sensor?
Old Sep 22, 2013 | 06:51 PM
Spillage's Avatar
Spillage
Default OEM Crank Position Sensor?
Who's the OEM for the crank position sensor on a '98 5.2L, manual trans?
And what brands are acceptable (long term) replacements?
I'm suspect of mine being on the way out... I have a (very) random misfire on the transition to mild acceleration.
I need to replace the O2 sensors (actually have them on hand), but will do them with the entire exhaust system in the next month or so (still need to buy the muffler & Cat).
The only other sensor that is not new is the cam position sensor, but doing the crank position sensor as a first option seems smarter... they're both original with 164K on them.
TiA.
Old Sep 22, 2013 | 09:13 PM
Paul DeHayes's Avatar
Paul DeHayes
I'd go for Standard Motor Products, as I've been hearing a lot of buzz about them around here for sensors. Not sure if they're the OEM or not though
EDIT: FYI, the P/N Rock Auto has for them in the SMP flavor is PC128 or PC128T for a 5.2 with a manual tranny.....
