P0135 1/1 O2S Heater Failure
Old Sep 27, 2013 | 06:45 PM
Novarider's Avatar
Novarider
Default P0135 1/1 O2S Heater Failure
What does this code mean? My truck is running great now but I got this code.
Old Sep 27, 2013 | 09:22 PM
dhvaughan's Avatar
dhvaughan
the O2 sensors are supposed to have 2 heater circuits in them to get them hot quickly. it the 2 white wires and they should have 12 volts on them when key is on.
the pcm somehow? determines that those heaters are not working. either by recognizing voltage or amp draw or the signal from the O2.
usually its just a failed O2, but if you've had a fire, verify that you have 12 volts on the whites.
