97 Ram 1500 shakes while driving
Old Oct 1, 2013 | 07:46 PM
dws111111's Avatar
dws111111
Default 97 Ram 1500 shakes while driving
hi... My son was using my truck (97 ram 1500) and I got the "call" he said my truck was shaking, told him to stay put and I would be there. while test driving it started shaking when crusing, I can let off the gas or press the gas hard and it quits but just crusing at about any speed it shakes. Put in reverse and it shakes also at any speed. Any ideas, Thanks
Old Oct 1, 2013 | 08:50 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Will move you to the correct spot now.
Old Oct 1, 2013 | 09:18 PM
dhvaughan's Avatar
dhvaughan
does it shake at idle? i would guess its skipping (misfiring). at idle, try disconnecting one plug wire at a time and see if one has no effect.
Old Oct 2, 2013 | 05:38 PM
dws111111's Avatar
dws111111
thanks, glad to be a member, idles a little rough, check engine light was on, checked it with a scanner and have misfire in #8 cylinder going to check plug/wire and do a compression test now. Will let you know what I find
Thanks for the response.
Old Oct 2, 2013 | 09:12 PM
dhvaughan's Avatar
dhvaughan
compression test and then leak down test (see youtube) as needed.
hopefully its just a bad plug, wire, or dist cap.
Old Oct 2, 2013 | 09:39 PM
ryan0714's Avatar
ryan0714
Dh thats what we ALL wish....
