oil in intake but its clean
Old Oct 2, 2013 | 11:31 AM
HollieDixson's Avatar
HollieDixson
Default oil in intake but its clean
ok so my truck has been chugging at times my cel light is on .
i replaced iac, pcv and axhaust components . i belive the cat is gutted sounds pretty hollow. i looked in the throttle body today to check for the plenum leak as most get. there is oil in there but its all clean oil so seems like it not leaking to me i may be wrong, but clean seems fine to me. should i suck it out or still replace the whole thing, its the oem plate did the magnet check.
any other suggestions, i just bought it and needs to pass echeck here soon. please help
ram girl!
Old Oct 2, 2013 | 12:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace it, and make sure the cat is really gutted, or replace it too. As well as o2 sensors.
Old Oct 2, 2013 | 01:09 PM
ram girl!
If your cat is gutted, it will certainly not pass echeck, if you are referring to emissions inspection. What is the code for? If it is O2, you could probably get by with the fouler trick,, but we need to know what the code is.
Old Oct 2, 2013 | 01:44 PM
BULLRAM's Avatar
BULLRAM
PM sent on the fix........
Old Oct 2, 2013 | 01:48 PM
zman17's Avatar
zman17
Be nice if the info was posted in this thread.
Old Oct 3, 2013 | 11:28 AM
HollieDixson
sorry gave the wrong code earlier if not at all. p0443 is for the purge solenoid.
im just going to rewire the damn thing today and see if it helps. ill check all my wires while im at it.
no codes for o2 anything tho if that helps, just the one code.
Old Oct 3, 2013 | 11:50 AM
BULLRAM's Avatar
BULLRAM
I have to PM it, other wise someone might think I was altering emissions.....
Old Oct 3, 2013 | 12:20 PM
Arde's Avatar
Arde
With all the guys with gutted cats., "test pipes", etc. I wouldn't worry about it. The cheap, easy fix for Harris County is...bootleg sticker, I've had several in the past when living there. Might be an option for the OP as well, depending on the location.
If the emissions problem isn't gonna be fixed, and the problem is the sticker, it's just a matter of choosing which law you're gonna break.
Buncha outlaws here.
Old Oct 3, 2013 | 09:46 PM
ru4dodge's Avatar
ru4dodge
Does anyone have the pin locationsto rewire this?
Old Oct 3, 2013 | 11:55 PM
chromed95's Avatar
chromed95
ram girl!
oil in the intake but it's clean oil. There shouldn't be oil in there to begin with?...Def sounds like a blown plenum to me, especially with the OEM plate! I'd look to get that fixed when possible. These other guys are providing you good info as well. Good luck!
