Headlight Switch compatibility '95 / '99 Ram
Old Oct 7, 2013 | 06:29 PM
bbostick's Avatar
bbostick
Default Headlight Switch compatibility '95 / '99 Ram
Needing to put in a new headlight switch in my 1995 Ram. Pulled a switch from the dash of a '99 truck while I was in the junkyard (cheep). while I doubt this is going to be a plug-n-play switch, will it work if I can get the wiring to match up?
I'm hoping I can avoid the issues with the older switches they used from '94 - '97.
Thanks in advance for any help or insight you can provide.
Old Oct 7, 2013 | 07:44 PM
xjarhead69's Avatar
xjarhead69
What was the issue they had with these switches? My 96 is original with 200,000+ miles on it.
Dave
Old Oct 7, 2013 | 07:55 PM
xjarhead69's Avatar
xjarhead69
As far a swapping switches, their not even close.
Do yourself a favor and buy the correct one and put it in there.
Bring up both switches on rockauto.com and compare.
I have done more then my share of rewiring vehicles and i would not wast my time on this.
I would spend the money on the right switch.
Dave
Old Oct 7, 2013 | 08:31 PM
topkin's Avatar
topkin
switches are cheap. I would just get a new one from the parts guy.
Old Oct 8, 2013 | 08:44 AM
bbostick's Avatar
bbostick
Default Thanks
That's kinda what I figured the answer would be. BTW, if you need a '99 Light/dimmer switch, it's free for the cost of shipping to anyone on this board
