Mode $06 test fail
Old Oct 13, 2013 | 12:35 AM
ngmillar's Avatar
ngmillar
Default Mode $06 test fail
Ok I am failing TID: $51 CID:$01 min 254 current 1
I have come across this site in my search for answers.
http://www.aatecusa.com/obdIIpro/mem...ex.htm#chryser
Basically I need help understanding what it means and what I can do or need to replace to fix the problem. I have an 01 Ram 1500 Sport 2wd. Thanks for any help guys.
Old Oct 13, 2013 | 12:24 PM
That test is for purge flow monitor. Apparently, it isn't seeing changes in engine RPM, or O2 sensor outputs when the purge valve is triggered. Bad valve? Clogged lines? Bad wiring?
Old Oct 13, 2013 | 01:05 PM
ngmillar's Avatar
ngmillar
Thanks by any chance could it also be related to a failing o2 sensor which I also know I have and need to replace.
Old Oct 13, 2013 | 01:09 PM
Possibly, but, there is more than one component to the test..... are you getting any codes? Or was this just the results of an emissions test?
Old Oct 13, 2013 | 01:19 PM
ngmillar's Avatar
ngmillar
I don't have any codes just the results of the test and only problems is a slightly rough idle but I figure that's just from the o2 and my cat possibly being clogged since the plenum was just done by me when I got the truck in August and I know it's been blown for awhile PO(step dad) never wanted to fix it though.
Old Oct 13, 2013 | 01:28 PM
Clogged cat and bad O2 could certainly contribute to that test failure. Best bet is to address the known problems first, reset PCM, and drive it for a while. I think there is a procedure to make sure all the monitors complete their tests in the shortest time possible, remember reading it here at one point, but, for the life of me, I couldn't tell you what it is.
Old Oct 13, 2013 | 01:33 PM
ngmillar's Avatar
ngmillar
Thanks appreciate all the help hopefully I can get these things fixed soon and everything will be goo
