Brake help please
Old Oct 13, 2013 | 04:00 PM
Novarider's Avatar
Novarider
Default Brake help please
I replaced the master cylinder in my truck(yes I bench bled it). When I replaced it I also replaced the fluid by bleeding the brakes till mostly clear fluid came out. I drove the truck afterwards and everything was great. Since then it has been parked for 2 weeks. I went to drive it yesterday and I have no brakes. Fluid level is at full just where I left it. I did not do anything special to bleed the system just the pump the pedal and crack the bleeder method. The petal goes all the way to the floor when the truck is running. Was there something else I was supposed to do? What would happen after 2 weeks that didn't happen when I replaced it? Did I not bleed the brakes enough?
Old Oct 13, 2013 | 04:15 PM
Ham Bone's Avatar
Ham Bone
Sounds like your master cylinder is a piece of junk tbh.
Old Oct 13, 2013 | 04:37 PM
AtomicDog's Avatar
AtomicDog
I'd try bleeding the system one more time and ensure that all fittings are tight and not allowing air into the system. Might still have a bit of air in the system somewhere. If that doesn't solve the issue, I'd remove the master cylinder and exchange it with your parts supplier.
Old Oct 13, 2013 | 04:56 PM
Novarider's Avatar
Novarider
This is the master cylinder I got. I plan on bleeding the system again once I can get some help.
http://shop.advanceautoparts.com/web...2-p#fragment-4
Old Oct 13, 2013 | 05:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Let me guess, A1 Cardone MC right? Junk IMO. But, as stated re bleed the system. You may now have a leak some where though. Check all your lines.
Old Oct 13, 2013 | 05:07 PM
Novarider's Avatar
Novarider
The only other MC available was $177 which is more than 3 times the price.
Is a Dorman better? Rock auto had a Dorman for $28
Old Oct 13, 2013 | 05:14 PM
Novarider's Avatar
Novarider
Where would the air be trapped to effect the entire system? Is the air trapped at the MC or wheel cylinder?
Old Oct 13, 2013 | 07:05 PM
AtomicDog's Avatar
AtomicDog
Could be in either place. Bleed the entire system, starting with the passenger side rear first, then the driver's side rear, then the passenger side front and lastly the driver's side front. Make sure that clean fluid is coming out of the fittings and that the fluid reservoir never gets too low during the bleeding process.
Old Oct 14, 2013 | 06:06 PM
Novarider's Avatar
Novarider
I don't have to do anything special to bleed the ABS system right? Just bleed the whole system by pumping the pedal and crack the bleeder valve right?
Is there a proportioning valve that needs to be bled or anything?
Old Oct 14, 2013 | 07:11 PM
AtomicDog's Avatar
AtomicDog
That will do it. Prop valve is in-line and will be bled as part of the process.
