starter troubles
Old Oct 4, 2005 | 06:17 PM
kgtazz's Avatar
kgtazz
Default starter troubles
1994 Ram 360 V8
FYI if you start having a sticky starter... pull starter off and remove case around brushes.
I have seen rust gather in this area. can be cleaned with light steel wool and solvent. be sure to clean
any residue and particles and coat with lots of wd40. starter will work like new.
rust occurs from small plastic plug in housing that tends to go bad. If you coat with liquid electical tape
it will help the plug to last a bit longer.
cheaper than spending $80 for a new one. helpful if stranded in the woods.
KG
