Vacum Leak?
Old Oct 6, 2005 | 04:38 PM
01ramclassic's Avatar
01ramclassic
Default RE: Vacum Leak?
ORIGINAL: steve00ram360
OK, well that was easier than I thought, on the right side of the intake manifold there is a vacuum port that has a line that goes to the firewall, there are 2 check valves on that line. one of those is your problem. the book says you can just unplug them and swap in a new one.
Hey thanks Steve. What side of the manifold is it on when I've got the hood opened and faceing the engine...my right or left? I looked on both sides and couldn't recongnize any check valves. Are they on a loose line or on the black rails running on each side of the manifold? Thanks again. -Tyler
Old Oct 6, 2005 | 05:39 PM
steve05ram360's Avatar
steve05ram360
right side = passenger side. they could be attached to a plastic vacuum line, becareful not to break it.
Old Oct 8, 2005 | 07:32 PM
magnum mike's Avatar
magnum mike
Hey steve, is that a factory book you have or not. and how much did u pay?
Old Oct 10, 2005 | 12:26 AM
steve05ram360
it's a factory manual that was a free to me...
Old Oct 11, 2005 | 12:52 PM
ljpierce_ely's Avatar
ljpierce_ely
yup, your right on the money. there's a vacuum line that goes thru the firewall to the a/c controller somewhere and there's a check valve that's gone bad. swap that valve out and you'll be good to go.
Now I'm beginning to feel like a total pinhead!! Never thought of replacing the check valve(s) on that line. Yes, I've got the same problem.
Since you have the factory manual, do they show the part number(s) for those valves? I'm heading to civilization today and can stop at the Dodge dealer to pick them up.
Old Oct 11, 2005 | 02:03 PM
steve05ram360
no they dont show the p/n's [:@]
Old Oct 11, 2005 | 02:09 PM
Silver_Dodge's Avatar
Silver_Dodge
I once had the same problem, but my check valve was fine. It turned out that the vacuum line that runs along the passenger frame rail next to the exhaust got a tiny hole burned into it by the exhaust. It was about $30 and 20 minutes to fix.
Old Oct 28, 2005 | 03:19 PM
ljpierce_ely
I'll take a look at that area. But with my luck, I can't believe it will be that easy for me!! hehehehehe
Old Oct 30, 2005 | 02:18 AM
bri's Avatar
bri
My 98 had the same problem. The solution was replacing the check valve at the intake manifold on the passenger side. Just pull off your check valves, put your lips around the correct end, and inhale. If the valve stops you from pulling air through then it's good. They're five bucks at the dealership.
Old Oct 30, 2005 | 12:40 PM
ljpierce_ely
For a second after the "inhale" part, I was expecting a punch line!!<bg> Thanks for the info on the pricing!.
