96 Ram 1500 4wd with a 5.9- needs tune up
Old Oct 29, 2013 | 11:35 PM
Jmarcin86's Avatar
Jmarcin86
Default 96 Ram 1500 4wd with a 5.9- needs tune up
I'm wanting to do a tune up on my truck and not sure what all I need to replace and what are the best places to get great parts that will last for a long time. My truck has 159,000. I just got it about a week or 2 ago and I don't think it has every had a tube up!!
Old Oct 29, 2013 | 11:46 PM
TheBigRedTruck's Avatar
TheBigRedTruck
Plenum for starters. spark plugs, transmission fluid, oil, o2 sensors (NTK), make sure hoses aren't cracked, serpentine belt isn't cracked, if you want you can replace the timing chain and water pump (done together usually) because more than likely the chain has been stretched if never replaced.
Old Oct 29, 2013 | 11:51 PM
Jmarcin86's Avatar
Jmarcin86
Thanks...... Where is a good places to get long lasting parts? I want parts that will last for long time!
Old Oct 29, 2013 | 11:54 PM
TheBigRedTruck
online usually. hughes engines has the plenum repair stuff. timing chain get a double-roller as suggested on DF (not sure where to get it)
Old Oct 29, 2013 | 11:59 PM
Jmarcin86's Avatar
Jmarcin86
Thanks again...... I will post if I find anything so I can get thoughts about products and companies.
Old Oct 30, 2013 | 12:19 AM
ryan0714's Avatar
ryan0714
look on rockauto.com when you pull a part up it will give a list of the ones offered, there will be one that has a heart <3 icon next to it, thats gonna be the one that is bought the most by other people so its normally gonna be your best bet.
here is a list of what id do.
plenum repair kit with all new gaskets.
new spark plugs and wires
new cap and rotor
new pre-cat o2 sensor from NTK
new thermorstat
new water pump and timing chain if your gonna do it.
new air filter
clean the IAC sensor and the port on the thrrotle body
new oil and filter
and seafoam it
also make sure you disconnect the neg. battery terminal before doing anything with any sensors.
Old Oct 30, 2013 | 12:33 AM
Jmarcin86's Avatar
Jmarcin86
Originally Posted by ryan0714
look on rockauto.com when you pull a part up it will give a list of the ones offered, there will be one that has a heart <3 icon next to it, thats gonna be the one that is bought the most by other people so its normally gonna be your best bet. here is a list of what id do. plenum repair kit with all new gaskets. new spark plugs and wires new cap and rotor new pre-cat o2 sensor from NTK new thermorstat new water pump and timing chain if your gonna do it. new air filter clean the IAC sensor and the port on the thrrotle body new oil and filter and seafoam it also make sure you disconnect the neg. battery terminal before doing anything with any sensors.
Thanks! This will help me a lot!!
