95 Ram 1500 Skipping
Old Oct 30, 2013 | 10:18 PM
DPD751's Avatar
DPD751
Default 95 Ram 1500 Skipping
I have a 95 Ram 1500 4wd project truck with a 360 engine. It cranks fine and skips a little at idle and low speeds. At about 50mph, it is skipping BAD. If I gas it, it smooths out and if I drop my speed and rpm down seems to run ok as well. The check engine light also comes on and stays on until the engine is turned off. When restarted the light is off. Any ideas what could cause this?
Old Oct 30, 2013 | 10:40 PM
Welcome to DF! Moving this to the 2nd gen Ram section.
Old Oct 31, 2013 | 10:22 AM
Arde's Avatar
Arde
When was the last time the plugs, plug wires, dist. cap and rotor were changed? It might be time.
Did you use the key to see what codes you're getting? Turn key on- off, on- off, on and count the flashes and pauses for the codes.
Old Oct 31, 2013 | 10:28 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
+1 on Arde's comments.
