holley hp efi install on 94 ram 1500 4x4
Old Nov 1, 2013 | 09:06 PM
don d's Avatar
don d
Default holley hp efi install on 94 ram 1500 4x4
ive got a 5.9 block that I had built for a turbo i put magnum eq iron ram heads on mopar performance intake 4 inch turbo back exhaust pipe I have everything installed but the engine manegment I cant find anyone who knows how to install
Old Nov 1, 2013 | 10:04 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
If I understand what you are saying:
94-96 is OBDI harness. So you need a PCM to work with that and take note what kind of tranny. Auto tranny makes the PCM look for more stuff. Limited to mopar performance PCM from what I recall of folks around here.
Or you could go later year to get OBDII harness and associated PCM, plus an SCT tuner.
Old Nov 1, 2013 | 10:14 PM
Would have to change the trans too..... OBDII expects electronic governor pressure sensor and solenoid.
@OP: Do you have the EMS already? Or are you looking for one?
Old Nov 2, 2013 | 02:19 PM
don d's Avatar
don d
my ems is the holley hp. I thought about going obd 2 but I figured buying the holley hp efi would be simpler but was wrong but everything else went together fine
Old Nov 2, 2013 | 02:27 PM
Check thru here, see if your instructions are there.
Old Nov 2, 2013 | 06:22 PM
Hahns5.2's Avatar
Hahns5.2
I'm unsure if Holley EFI can use our cam/crank sensor arrangement.
MS3X can and is a lot cheaper.
