What fuse is blown?
Old Nov 2, 2013 | 11:17 AM
eddorr's Avatar
eddorr
Default What fuse is blown?
I have an intermittent blinker problem with 2001 ram 6cyl. It is in the 10 amp flasher fuse on the side of the dash. I had the engine running and had my test light in the hot side of the fuse. Accidentally hit the frame with my tester and it sparked. Engine shut down and have no power thru ignition or gages. Key dinger does work. Can not locate a blown fuse in the panel I was in or under the hood. Any suggestions?
Old Nov 2, 2013 | 03:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
You can check fuses 9 or 5 for power in the junction block, thats on the side of the dash. But I would check all fuses.
Old Nov 2, 2013 | 03:53 PM
ryan0714's Avatar
ryan0714
did you check the IOD fuse?
