U-joints question
Old Nov 5, 2013 | 08:49 PM
Blue Mopar01's Avatar
Blue Mopar01
Default U-joints question
I was greasing my truck in auto shop and seen that my front two u-joints are going out. What's the best brand of u-joints (or doesn't it matter) and any helpful tips for when I replace them?
Old Nov 5, 2013 | 08:56 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I went with spicer ones. Don't recall the p/n but I can try to find it. About 28 months and counting.
Old Nov 5, 2013 | 08:59 PM
dhvaughan's Avatar
dhvaughan
i like the greaseable Precision brand. The super-strengths are massive, but they do require the grease fitting adaptor and don't use zerks, which is a bit of a pita.
this thread is about front axle ujoints, but it applies to drive shaft
https://dodgeforum.com/forum/2nd-gen...984-uh-oh.html
Old Nov 5, 2013 | 09:07 PM
Arde's Avatar
Arde
Moog #377, greasable.
Old Nov 5, 2013 | 09:20 PM
kejobe's Avatar
kejobe
I had the Precision non-greasables. Went bad in a year. Got Duralast Gold's from Autozone in now. So far, so good.
Old Nov 5, 2013 | 09:23 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
The search function works around here, yay.
https://dodgeforum.com/forum/2nd-gen...ml#post2606204
~$30 a pop, shop around
http://www.fourwheeler.com/product-r...u-joint-jeeps/
Old Nov 5, 2013 | 09:25 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Seeing dhvaughn's post are we talking about the axleshaft ujoints or the driveshaft? Never had to do driveshaft....yet.
Old Nov 6, 2013 | 07:59 AM
Blue Mopar01
Hey thanks guys for the insight, I should of been more specific when I said my front two u-joints (axle shaft ones). I was curious if there were better brands out there, I'd like greasable u joints. That and I've never replaced axle shaft u joints on my truck and thought there might be some helpful tips on installing.
Old Nov 6, 2013 | 08:35 AM
CSDavies26's Avatar
CSDavies26
I go with moog everything on mine...their u-joints are greasable and come with zerc fittings. I have moog ujoints and wheel bearings in the front and so far so good...got them from advance auto.
Old Nov 6, 2013 | 06:49 PM
dhvaughan's Avatar
dhvaughan
The Moog brand is a re-labeled Precision. Federated bought out one or the other? They're very good, but see my link above to Sheriff's thread for the required grease gun adapter.
OP - rent the ball joint press from your local parts store to remove/install the joints into the yoke. it's a lot better than bashing the hell out of everything with a hammer. another tip - before installing, remove the cap and put a liberal amount of grease into it to hold the needle bearings in place.
