Coolant Temp Sensor Help
Old Nov 8, 2013 | 12:57 PM
BackInBlack43's Avatar
BackInBlack43
Default Coolant Temp Sensor Help
Anyone know any tricks to changing the coolant temperature sensor without having to take off the alternator to get to it? i will obviously do this if i have to but i figured id try to see if anyone knows anyways around this.
Old Nov 8, 2013 | 05:29 PM
ngmillar's Avatar
ngmillar
When I changed mine I had to move the alternator out of the way but its only three bolts so might as well do it just to make it easier anyways.
Old Nov 8, 2013 | 08:44 PM
BackInBlack43
Yeahp that what I wound up doing haha. PITA. But on another note, I changed the sensor and the dash still isn't reading any temperature at all. It worked fine and when I changed my ac compressor and started the truck up that's when it stopped working. It worked fine before then. Anyone have any ideas?
Old Nov 8, 2013 | 10:37 PM
Ham Bone's Avatar
Ham Bone
did you disconnect the battery? if not disconnect battery cut your headlights on for a couple secs and then plug it all back up
Old Nov 10, 2013 | 03:07 PM
BackInBlack43
yeah that didnt do anything either. thinking i have a gremlin in some electrical wiring somewhere from when i did the ac compressor =/
Old Nov 10, 2013 | 04:35 PM
ryan0714's Avatar
ryan0714
could be the cluster itsself. they are known to give fits sometimes, normally its with the oil pressure gauge though.
Old Nov 10, 2013 | 08:43 PM
dhvaughan's Avatar
dhvaughan
if it worked before, but now it doesn't - look for damage to wiring, connector, etc.
Old Nov 11, 2013 | 09:46 AM
97r/tram's Avatar
97r/tram
There's two different ones. The one next to the ac compressor controls the gauge. The one next to the alternator give the PCM its reading.
Old Nov 11, 2013 | 09:47 AM
In 98 that changed. Only one sensor, and the PCM clues in the cluster via the central timer module what temp to show.
Old Nov 11, 2013 | 09:49 AM
97r/tram's Avatar
97r/tram
What about pre 96?
