hard starting
Old Nov 20, 2013 | 08:16 PM
heminutt's Avatar
heminutt
I did a fuel presser test it stays steady ant 52psi when running with ignition on it read 7 psi then I cycled ignition on and off 3 times and it read 55 psi but dropped down to 5 psi in like 3 sec.
Old Nov 20, 2013 | 08:59 PM
Did it hold after that?
Old Nov 20, 2013 | 10:06 PM
dhvaughan's Avatar
dhvaughan
i'm going to rewrite it in sequence and put some punctuation on it. correct me if i'm wrong.
cold engine....
turn ignition to on for the first time - 7 psi.
cycle ignition on/off 3 times - initially reads 55 psi but immediately drops to 5 psi after 3 seconds.
start engine and leave it running - holds a steady 52 psi.
assuming you have no fuel leak spraying fuel all over the ground... i read this as a bad fuel pump. see what others say.
Old Nov 20, 2013 | 10:51 PM
heminutt's Avatar
heminutt
thanks for rewriting it and there is no fuel leak.
Old Nov 20, 2013 | 11:04 PM
dhvaughan's Avatar
dhvaughan
see what merc or hey-you say. fuel pump is expensive.
you might just do the on/off/on/off cycle and drive on.
Old Nov 20, 2013 | 11:31 PM
lance49726's Avatar
lance49726
Originally Posted by lance49726
By turning your key off and on, your priming your fuel pump so sounds like your losing your prime in the fuel pump.
That is what happened to me having to do the key dance and it was the fuel pump. And dont buy a cheap pump they dont last long i know.
Old Nov 20, 2013 | 11:40 PM
lance49726's Avatar
lance49726
Fuel pump is expensive but if you can afford it fix it. Better then being stranded on a lonley road at -20 F.
Old Nov 21, 2013 | 11:19 AM
If the pump builds the correct pressure, and will run the engine just fine, the problem isn't the pump, its the drain-back valve, that is part of the regulator. Rumor has it you can change JUST that part. Much cheaper than the whole pump.
Old Nov 22, 2013 | 09:29 AM
heminutt's Avatar
heminutt
does any one else no if you can change the drain-back valve without getting a new pump
Old Nov 22, 2013 | 10:13 AM
Here's one..... 115 bucks though.... and you still have to pull the whole pump to change it..... More expensive than I had thought.
Quite frankly, if I were going to go to all that trouble, I would change the whole thing. No point doing the job twice. ('cause ya just know that two weeks after you change that regulator, the pump will die.... right after you fill the tank.....)
