Fluid leak when driving off after parked for days
Old Nov 12, 2013 | 11:45 PM
james2012's Avatar
james2012
Default Fluid leak when driving off after parked for days
I bypassed my leaking heater core on my '99 Ram 1500 a few years ago -- runs fine. Awhile back I noticed my passenger floorboard is soaked with water after using the AC ... OK, so I use my AC/defroster less frequently. But I notice now, when I move my truck after not starting it for a few days when I drive off a stream of watery fluid follows behind me for about 8-10 yards until there is none left. I thought for awhile it was rain water leaking from my bed, but I noticed the fluid flows in a funnel shape behind me that starts at about the place under the truck where the back of the engine/dash is. My coolant level never drops below normal and I never have puddles or leaks under the truck -- I also changed my waterpump a couple of years ago. Any ideas???
Old Nov 13, 2013 | 12:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
Has it been raining a lot where you live?
Old Nov 13, 2013 | 12:18 AM
james2012's Avatar
james2012
It has rained some, but I am not sure where the fluid is being trapped and why it only spews behind me as I drive off and not why the truck is idling.
Old Nov 13, 2013 | 02:34 AM
Ram Driver's Avatar
Ram Driver
Could it be condensation from the exhaust ?.
Old Nov 13, 2013 | 06:53 AM
dhvaughan's Avatar
dhvaughan
look on the firewall, passenger side, down low, below the pcm and see the 5/8 inch tube that sticks out about 1/2 inch. that's the drain from the AC/defroster condensation pan.
it might be coming from that. and if you are parked with the front end up, its not able to drain.
you can gently poke a wire or long zip tie into the tube to clean out any mold buildup or insect or other debris.
Old Nov 13, 2013 | 12:17 PM
james2012's Avatar
james2012
Thanks for the suggestion, guys! I will check the condensation drain pan. I'm sure the fluid leak is related to the leak on the passenger side floorboard.
