Heat blowing to floor only?
Old Nov 13, 2013 | 10:55 AM
ScreamingNeedle's Avatar
ScreamingNeedle
Default Heat blowing to floor only?
97 Dodge Ram 1500. Anyone know why my heat blows to the floor vent only? Turn the selector **** and nothing changes?
Old Nov 13, 2013 | 11:40 AM
Bad control switch, stuck doors in the heater box, broken vacuum lines. Need to have a look under the dash, and see whats up.
Old Nov 13, 2013 | 02:09 PM
97r/tram's Avatar
97r/tram
I do know that loss of vacuum from either one of the lines going to the intake vacuum source will result in defrost only. Sounds like a blend door stuck closed.
Old Nov 18, 2013 | 10:25 AM
Luigi1500's Avatar
Luigi1500
Ah-HA! Glad I saw that, after some engine bay work I found I only have defrost and a loud hissing coming from the engine bay... You just confirmed my suspicion of a cracked vacuum line! THANKS! Now I just have to find it, ugh
I also second your "Blend door stuck" opinion too. I read one guy said he had a similar problem, but after changing the selector back and forth a few times each time he got in the truck, it broke free after a few days. Worth a shot, hell of a lot easier than pullin the dash!
