1995 Ram 1500 4x4 5.9 efi engine
Old Nov 13, 2013 | 05:48 PM
GreatBears1r's Avatar
GreatBears1r
Default 1995 Ram 1500 4x4 5.9 efi engine
Have installed new engine and new everything electrical including ECM modual,plugs ,sensors,plug wires,coil, everythng.
Engine starts and idles just fine, would run all day if i let it.
Then if i drive it it misfires when engine is at about 2000 rpm.
When i take my foot off gas it will idle just fine. But driving 5 mph gets me nowhere.
I live 168 miles north of Fairbanks,Alaska so i need to be able to correct these issues here at home.
I Truely need an experts help with this.
Thank you.
Old Nov 13, 2013 | 06:15 PM
What prompted the new engine? Did you replace O2 sensors?
Even if you did, try unscrewing the front O2, and take the truck for a drive. If its better, that indicates the cat is clogged, and it needs to go. (you can just hollow it out, cut if off and replace it with a piece of pipe, or replace it with an aftermarket unit.....)
If that doesn't help, is there a local shop with a scanner, that can check fuel sync?
Old Nov 14, 2013 | 06:08 PM
GreatBears1r
Original engine took a hit from failed thermostat and cooked at -58 below.
And yes everything that is involved with a running engine has been replaced.
As stated it will run finefor hours, just not when throttle is added.
There is nothing local, nearest shop is about 170 miles south of here.
What needs to be done to sync injectors ??
Old Nov 14, 2013 | 08:38 PM
dhvaughan's Avatar
dhvaughan
170 miles. damn.
general info=
http://bionicdodge.com/Download/Cams...uel%20Sync.pdf
about halfway down this page is a how-to using an ohmmeter. it might get you closer than your are now, maybe close enough.
http://www.justanswer.com/dodge/2b9v...-2l-motor.html
