Help, Went mudding Wiring problem?
Old Nov 19, 2013 | 08:08 PM
Zumiez190's Avatar
Zumiez190
Default Help, Went mudding Wiring problem?
Went mudding in my 1996 dode ram 2500 v10 2wd yesterday, now my abs light is on, brake light,air bag light is all on. my windows wont even row down.
Cant figure out what the problem is, resetting the ecu but that didnt work now im trying to leave the battery unplug overnight.
Old Nov 19, 2013 | 08:19 PM
Welcome to DF. Bolded your problem...lol...sounds like something got wet. How bad was the mud? You got it caked everywhere? Did it get into the engine compartment? Have you cleaned it off?
Old Nov 19, 2013 | 08:31 PM
Zumiez190's Avatar
Zumiez190
The whole bay is muddy, it was a pretty big puddle of mud and pretty deep, first time muddin in my own truck actually so i went up and played around and im thinkin i may of got some wires wet? hopefully not my ECU!?
Old Nov 19, 2013 | 08:38 PM
Welp, I'd start by cleaning everything off. Then start disconnecting connectors and cleaning/drying them. Maybe distributor cap, wires, etc. Not that familiar with a V10 so maybe some others will chime in but obviously something got wet that was not supposed to get wet if it ran fine before.
Old Nov 19, 2013 | 08:41 PM
Zumiez190's Avatar
Zumiez190
Exactly what i was thinking ^
Old Nov 19, 2013 | 09:09 PM
I would check the fuse center in the engine bay. Maybe it's slap full of mud...
Old Nov 19, 2013 | 10:08 PM
moe7404's Avatar
moe7404
if it has a dist cap like a small block or big block. it might have a vent, IE hole, in the cap, if so plug the vent with JB-weld.
Old Nov 20, 2013 | 11:56 AM
97r/tram's Avatar
97r/tram
ABS and brake is from the rear diff speed sensor. Probably got some deposits on it from spinning the tires in the mud and the metal suspended in the gear oil sticking to the sensor.
Old Nov 20, 2013 | 03:24 PM
95' 360 Ram's Avatar
95' 360 Ram
I had the same problem but some wires got unplugged by the steering column.
Old Nov 20, 2013 | 05:44 PM
Zumiez190's Avatar
Zumiez190
Default Update
Well boys turns out there leaving your battery un hooked all night worked, even got a truck wash today so hopefully that works now
Last night my truck threw these codes
P0505
P0144
Dont know what the p0144 means it threw that code before but cleared it and shown up a week later. Also if a OX sensor is out does that kill your gas more?
