Off road Y pipe
Old Nov 23, 2013 | 12:30 AM
Thornloe Pride's Avatar
Thornloe Pride
Default Off road Y pipe
Anyone here runnin the Jeg/Summit off road y pipe? Notice any gain in performance/mileage? I am in the process of modding my truck and i have read that the stock y pipe is very restrictive in our trucks. I already have the summit/pacesetter shorties so I think a less restrictive y pipe will really let my truck flow. I think it would work well alongside my CAI, SCT and recently installed fastman TB
I have a few questions though. The summit y pipe is designed for pacesetters quick trip long tube headers so I do not believe they will fit with my shorties. If they were able to fit, I would gut my cat because its getting pretty plugged up.
http://www.summitracing.com/int/part...1183/overview/
The Jeg y pipe is a little more than just a y pipe. It comes with no cat and holes pre drilled into the pipe for 02 sensors. I don't live in an area with emission tests so having no cat wouldn't affect me. I have read that guys put fake 02 sensors in to trick the truck into thinking the cat is still there but why couldn't a person just use real proper NtK sensors?
http://www.jegs.com/i/JEGS-Performan...d=#moreDetails
The Jeg y pipe seems to be the better deal, especially if the summit y pipe isn't compatible with my headers. Anyone got some advice? Thanks
Old Nov 23, 2013 | 01:29 AM
dhvaughan's Avatar
dhvaughan
the jeggs pipe is a direct bolt on to replace the factory front pipes, Y, and cat. mine fit perfectly. no personal experience, but if the short headers replace the factory manifolds, and fit the factory Y pipe, then this is the perfect match for it.
lots of pics here.
https://dodgeforum.com/forum/2nd-gen...-this-fit.html
Old Nov 23, 2013 | 01:56 AM
Ham Bone's Avatar
Ham Bone
You can't use a normal read o2 sensor because all the tear does is check that the cat is functioning. And sense it's not, because there is no cat there, it will throw a code
Front o2 is critical for proper a/f ratio and open/closed loop
Old Nov 23, 2013 | 02:14 AM
dhvaughan's Avatar
dhvaughan
i don't know why some do and some don't, but my 01 doesn't trip a cel with no cat.
Old Nov 23, 2013 | 10:16 AM
Arde's Avatar
Arde
The non-fouler trick for the rear O2 sensor with the missing cat., isn't the purpose of that to prevent the CEL from coming on?
Not that it matters to me, only have one sensor.
Old Nov 23, 2013 | 10:22 AM
dhvaughan's Avatar
dhvaughan
^yes. the non-fouler acts as a spacer and in theory slightly reduces the exposure to the exhaust stream. it should only be used on the rear O2.
Old Nov 23, 2013 | 01:51 PM
Thornloe Pride
lots of pics here.
Thanks for the thread. Lots of good advice there. I think I'll go with the jegs Y pipe. Did you notice any performance/mileage gains?
Old Nov 23, 2013 | 05:04 PM
Blue Mopar01's Avatar
Blue Mopar01
I have the Magnaflow off road y pipe w/ my pacesetter shorties and SCT. I noticed a little medium to upper rpm gain, little faster throttle response and hitting it hard she moved a tad faster. Overall I'd say I gained some power from it.
Old Nov 23, 2013 | 06:24 PM
dhvaughan's Avatar
dhvaughan
couldn't tell you. even my 87 year old mother drives faster than me.
