some kind of noise
Old Oct 6, 2005 | 08:14 PM
mossy765's Avatar
mossy765
Default some kind of noise
when i accelerate their is this noise but it only does it when i accelerate can anyone tell me what that noise is? thanks
Old Oct 6, 2005 | 09:04 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: some kind of noise
Um...the motor revving? Your exhaust? Maybe loud or uneven/poorly worn tires?
Can you describe the sound? [&:] [>:]
Old Oct 6, 2005 | 10:26 PM
mossy765's Avatar
mossy765
its really hard to explain it but i thought it was the tubes that get the gas to the engine. its kind of a squeling noise.
Old Oct 6, 2005 | 11:23 PM
BIGSEXY's Avatar
BIGSEXY
Could be a u joint...
Old Oct 7, 2005 | 03:53 AM
01ramclassic's Avatar
01ramclassic
Check to see if your air intake tube is loose on your air intake box. Sometimes the tube slips off a little and air gets sucked through the crack where they connect and makes a swishing sound when accelerating. I would check that first. If it is loose just push the tube back on the air box. Hope this helps. -Tyler
Old Oct 7, 2005 | 04:13 AM
otonkyo's Avatar
otonkyo
What kind of noise is it ? Is it a sissssling noise or thumping noise?
Old Oct 7, 2005 | 12:11 PM
steve05ram360's Avatar
steve05ram360
uh, yeah, more details are needed [sm=icon_stickpoke.gif] but the most common problems have been mentioned already, leaky seal on the throttle body to air hat (the part that goes to your air filter), it's probably just loose. another possiblity is your accessory drive belt is worn to the point that it can no longer grip well during acceleration.
Old Oct 8, 2005 | 12:34 AM
mossy765's Avatar
mossy765
where is the air intake box in a 1999 Dodge Ram 2500? Ryan
Old Oct 8, 2005 | 04:09 AM
shott8283's Avatar
shott8283
take it to a shop brother![]
