9.25 and Dana 44 Question
Old Nov 24, 2013 | 12:49 PM
Jeff_S's Avatar
Jeff_S
Default 9.25 and Dana 44 Question
Hey all,
I need to know what the stock ratios are for the Chrysler 9.25 rear axle and the Dana 44 front axle for a 1999 ram 1500 4wd. I can't find this info anywhere!
Old Nov 24, 2013 | 12:51 PM
BIGRED97's Avatar
BIGRED97
under the hood there should be(or there used to be) a sticker that would give you the info.
but its 90% most likely that you are geared at 3.55 if its an offroad edition 4.10. But most likely its a 3.55 ratio
Old Nov 24, 2013 | 01:17 PM
armynurse's Avatar
armynurse
If you got the towing package you would get a 3.90 ratio. If you've got the 3.55 and are putting 33" tires on, skip the 3.90 and go for the 4.10.
Old Nov 24, 2013 | 01:47 PM
Ham Bone's Avatar
Ham Bone
Eh I'm almost 100% sure the towing package just had 3.55 gears. Only ORE had different. I have the towing package, heavy duty package, blah blah blah and I only have 3.55 gears.
I think your thinking of newer model trucks that do have 3.92 ratios available
Old Nov 24, 2013 | 02:07 PM
Spillage's Avatar
Spillage
My '98 1500 4x4 (w/Tow Package) came with 3.55's.
Old Nov 24, 2013 | 03:15 PM
merc225hp's Avatar
merc225hp
The 3.92 gears were a opt back then, very few of these out there.
Edit: I was just looking at my window sticker, 3.92 N/C so it must have been in a package but what one idk.
