360 gas to cummins conversion
Old Nov 24, 2013 | 04:46 PM
Vtfarmer's Avatar
Vtfarmer
Default 360 gas to cummins conversion
I got a 1997 dodge 2500 with 360 gas and I want to make it a diesel. I can get parts pretty easy and good price. Just was wonder what I would need to take out and replace. Like suspension, trans, tranfer case and rear end? Please HELP!
Old Nov 24, 2013 | 05:35 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Easiest will be to have your own donor rig sitting right next to the rig your going to transplant into. Try doing a search as there is a thread on here that is pretty current with someone who just swapped a 4BT into their truck. They would be able to answer your questions.
Old Nov 24, 2013 | 08:21 PM
AppelH's Avatar
AppelH
What transmission do you har now? If you have an auto, you need to upgrade. Won't handle the power and I'm pretty sure they won't bolt up. You need to make sure you have a Dana 60 front axle, my 2500 did, they all might I'm not sure. A 12 valve would be easiest, because they are simple. The front springs need to be upgraded to handle te heavier diesel, otherwise it be saggin. Motor mounts I'm not sure. Exhaust will be different also
Old Nov 24, 2013 | 08:45 PM
Ham Bone's Avatar
Ham Bone
All 2500 have front dana 60 unless you have one those early "light duty" gassers that had 44/9.25
Tranny unless you have nv4500 then you will need a bellhousing
T case (probably just swap input shafts)
Diesel springs
Dash cluster
Fuel pump
Fuel lines???
Rear axle, 70/80 not 60
Motor mounts???
Power steering pump, the diesel one is different somehow I think, can't remember
Exhaust, but that will be easy
Old Nov 24, 2013 | 09:48 PM
Vtfarmer's Avatar
Vtfarmer
I got the auto trans (46RE), I heard though you can get a new torque converter? But not sure just heard it?
Old Nov 24, 2013 | 09:55 PM
AppelH's Avatar
AppelH
The 46 wouldn't handle the power without serious upgrades.
Old Nov 24, 2013 | 09:56 PM
Ham Bone's Avatar
Ham Bone
I don't think it will even bolt up
Old Nov 24, 2013 | 10:00 PM
AppelH's Avatar
AppelH
Agreed
Old Nov 25, 2013 | 09:49 AM
97r/tram's Avatar
97r/tram
The 47RE in the diesels use a different bellhousing.
Old Nov 25, 2013 | 12:09 PM
46 Won't bolt to diesel.
What kind of shape is the donor truck in? If it's better than yours, just run it. if the mechanicals are good, and just the body is rough, swap the better body on. Otherwise, you would probably spend less by just buying a diesel truck.
