Rearend assy 2wd or 4wd compatibility
Old Nov 29, 2013 | 02:47 PM
valleyd01's Avatar
valleyd01
Default Rearend assy 2wd or 4wd compatibility
I have a 98 Ram 1500 2wd with the tow package which has a limited slip 3.55 gear ratio. I need to rebuild what I have or replace the assembly from a salvage yard due to whining/roar sounds. Trying to do some research and I am getting conflicting results about weather I can use the rear end assembly from a 4wd Ram 1500. Some people say there is a difference between the leaf spring perch height on the axle tubes. I believe I can use the rear end from years 1994-1999 with 2000 and newer 1500's using a different style pinion yoke.
Old Nov 29, 2013 | 11:51 PM
merc225hp's Avatar
merc225hp
4wd trucks get a block 2wd don't. If they are different it won't be much, take a tape measure with you so you can compare. My perches were about 1/2"-3/4" above the diff tube if that helps you at all. I still have the old ones if you need a exact number for comparison.
Old Dec 2, 2013 | 02:31 PM
valleyd01's Avatar
valleyd01
Ok thanks, yeah I will be going later this week to look at some rear ends at junkyard/craigslist and will measure then. I believe that should be the only issue if any.
Old Dec 2, 2013 | 02:51 PM
dlyter09's Avatar
dlyter09
Why not just rebuild the rear end? It could be done for around 600 bucks.. I would rather go that route than a junkyard where you have no clue what you are getting into
Old Dec 2, 2013 | 03:22 PM
97r/tram's Avatar
97r/tram
Also the shock mounts on the axle are more horizontal than the 2wd being more vertical.
Old Dec 2, 2013 | 05:42 PM
Don't think it would matter much even if they were different.
Old Dec 2, 2013 | 06:18 PM
97r/tram's Avatar
97r/tram
If he grabs a 4wd rear end, his shocks will be compressed farther 3" up
Old Dec 2, 2013 | 07:31 PM
Shocks on the 4x4 are longer than the 2wd. If he uses the shocks he has on his truck now, it won't matter.
Old Dec 3, 2013 | 09:31 AM
97r/tram's Avatar
97r/tram
From rockauto.com-
MONROE Part # 37103 Sensa-Trac Light Truck Rear; RWD
Compressed Length 15.500"
Extended Length 24.625"
Travel 9.125"
Parts Pack None
MONROE Part # 37105 Sensa-Trac Light Truck REAR; 4WD
Travel 9.125"
Parts Pack None
Old Dec 3, 2013 | 11:53 AM
Interesting. Would like to see some pics of the shock mounts on the 4 vs. 2 wd axles.
