help with vac lines under hood, need pics
Old Nov 29, 2013 | 06:47 PM
CoryVolkenant's Avatar
CoryVolkenant
Exclamation help with vac lines under hood, need pics
Ok guys I pulled my intake off about 4 months ago to do the plenum and then some stuff came up and now im gonna finish the job tomorrow, problem is i dont remember where all the vac lines and air caps and miscellaneous stuff goes i actually took the axles off the radiator out all the drive accessories off pulled the entire interior and removed the bed ( truck was in very shape) got new axles in it all new interior brand new bed on it a fresh 5 in lift kit 1 ton steering new brakes new hubs new motor mounts and new freeze plugs already put on the double roller chain and new plugs wires cap and rotor got a new water pump ready to go on and all new belts pulleys tensioner and hoses but now to putting motor back together i need some photos of there everything connects( i know im a idiot i should have taken photos before i pulled it apart) so any pics under hood would help so much my trk us a 1998 1500 long bed with gas 5.9 360
Old Nov 29, 2013 | 07:15 PM
moe7404's Avatar
moe7404
you dont have a factory service manual?
Old Nov 29, 2013 | 09:26 PM
CoryVolkenant
yes but its not like seeing the real thing
Old Nov 29, 2013 | 10:44 PM
Should be a label under your hood as well.
Old Nov 29, 2013 | 11:24 PM
merc225hp's Avatar
merc225hp
This may or may not help you.
