transfer case noise
  #21
Old 12-02-2013, 12:22 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Originally Posted by dragracer501
well I do know when I changed the filter the last time there were 3 pieces of what looked to be a ring they were about an 1/8th inch thick and I was told they were from a band inside the transmission could that be it cause I don't even know exactly what the pieces came from
It very well could be. But you would be noticing shifting issues with the truck if you lost bands. Try swapping cases around and if that doesnt improve the noise then you may want to start looking into the transmission. When I was having issues another member here was trying to help me track the issues down. He was on the right course if I remember correctly. Merc225 it was. Just dont want to see someone go through the issues I did and spend that kind of money on transfer cases when it ends up being transmission related
  #22
Old 12-02-2013, 12:24 PM
dragracer501's Avatar
dragracer501
dragracer501 is offline
ya well the tranny hasn't acted weird everyonce in a while when its cold and it goes to shift it will shift up then back down really wuickly and it doesn't reall shift hard and I towed with it all summer and it didn't make it better or worse the only thing was the noise started at like 74 but I don't have any spare tcases or anything so that's is kinda an issue to find the problem
  #23
Old 12-02-2013, 12:36 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
Well start cheap like others said. Pull that tailshaft housing off and check the snap ring. If that is intact and hasnt moved then keep moving down the list..
  #24
Old 12-02-2013, 12:43 PM
dragracer501
if I pull of the tailshaft housing is there a gasket on the housing that I would need
  #25
Old 12-02-2013, 12:51 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
No just use black rtv sealer.
Those pieces you found in the trany pan are for the OD unit, The trany will fail soon, time to R&R it and rebuild it.
Originally Posted by dlyter09
The difference is like HeyYou stated. The VSS and shift pattern.. Not 100% sure on swapping the tail shafts. I went through like 5 tcases with the same noice you describe. Eventually they just split in half and spilled their guts out on the highway. If you replace the transfer case and still encounter issues your next step is the transmission.. Thats what mine ended up being. Guy that bought the truck had the same issue with his and there was an internal issue in the trans. Cant remember exactly what he said it was though..
Really! I wish you could remember what it was, I have not followed up on this for a while.
  #26
Old 12-02-2013, 12:57 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
I wanna say he said something about the pump.. Maybe the torque converter.. Im trying to remember.. I know we were talking back and forth for a while and you had said something about the transmission
  #27
Old 12-02-2013, 12:58 PM
dragracer501
ya that makes sense cause when it shifts out of overdrive the noise almost is gone.
  #28
Old 12-02-2013, 12:59 PM
dragracer501
could maybe the converter be coming loose
  #29
Old 12-02-2013, 01:00 PM
dlyter09's Avatar
dlyter09
dlyter09 is offline
I guess I just looked over that information.. Then Merc is correct.. Rebuild is in order.
Edit: The converter coming loose is possible I suppose.. Could also just be on the downhill with whatever debris is floating around in there.
  #30
Old 12-02-2013, 01:02 PM
dragracer501
alright that wasn't what I wanted to hear but thanks a lot guys!
Quick Reply: transfer case noise
