Heater Core replacement issues
Old Dec 8, 2013 | 06:11 PM
JoshHager's Avatar
JoshHager
Default Heater Core replacement issues
i have a couple question. I replaced me heather core yesterday in my 1999 Dodge Ram 1500. 5.2L V8
After following all the steps and getting the new heather core and and everything back together I noticed a few things. My ABS light now comes on. After driving it for a bit a also notice that my emergency break light comes on and my speedometer does not work properly. The speedometer at times goes to 120mph when I am only doing about 30mph. When I noticed that I pulled over put the truck into park to setup my GPS which will tell me my speed. When I started driving again my speedometer was a little more accurate. However this time it was about 5 - 10 mph under the actual speed. Any idea what might have caused this? Are there specific wires I should be checking to make sure they are properly connected? Any advice on this would be appreciated. Thanks
Old Dec 8, 2013 | 08:27 PM
xjarhead69's Avatar
xjarhead69
Make sure all grounds are back in place.
Dave
Old Dec 9, 2013 | 12:12 PM
Ramman18's Avatar
Ramman18
It appears the speed sensor died coincidentally. It is on the top of the rear diff and can be replaced easily.
Old Dec 10, 2013 | 07:42 AM
JoshHager's Avatar
JoshHager
I will go through and check all the grounds as that could be a possibility.
As for the speed sensor, I replaced that about 6 months ago. I guess it could be faulty but I don't think that is the issue.
