Wheel Hup replacement ..Torque
Old Oct 7, 2005 | 08:49 PM
just_lkn's Avatar
just_lkn
Default Wheel Hup replacement ..Torque
Last weekend during a oil change I notice a loose wheel bearing on by truck. No problem i thougth a few bucks for a new bearing and we will be fine.. Nice simple project for this weekend.. Well to my suprise [:-]from visiting this site , you dont change the bearing you change the whole hup... We wont even get into what the part cost [:'(] but is was strange it was actually 150.00 canadian dollars cheaper at the dodge dealer then it was a two other part suppliers.
The truck is a 2001 Ram 1500 4X4
Could someone tell me how tight to torque the spline and hub bolts.. also any advice on change this would be helpfull...
Old Oct 7, 2005 | 11:06 PM
tenntech's Avatar
tenntech
Default RE: Wheel Hup replacement ..Torque
The hub mounting bolts torque to 122 ft.lbs. and the axle nut torque is 180 ft.lbs.
Old Oct 7, 2005 | 11:07 PM
The Burning Rom's Avatar
The Burning Rom
Dana 44 Hub/U-Joint replacement info: http://www.pavementsucks.com/tech/hub.php
Old Oct 8, 2005 | 11:54 AM
Blackimpala's Avatar
Blackimpala
OK OK Iam new to this MOPAR stuff, but I just changed the u-joint on the front of my 96 2500 Dana 60. I didn't look that close at the wheel bearing but it looked like it could be pressed off and on. Are you saying that it can't be changed? And now I have heard three different troques for the front hub nut.
Old Oct 8, 2005 | 12:20 PM
mossy765's Avatar
mossy765
The same thing happened to mine. I went to go get new tires on truck and i found out out the the whole wheel bearing collasped in my front right tire and i had to take into a place here in town and they had it for a week and the cost was around $650 for a hub. Ryan
Old Oct 8, 2005 | 03:59 PM
The Burning Rom
ORIGINAL: Blackimpala
The torque specs in the link I posted are for the DANA 44. They are lower than the specs for the DANA 60, which has a much higher weight rating.
As far as the bearing, it is not serviceable unless you have access to a 20 ton press. Most people don't. I do believe that the 01 and newer trucks have serviceable bearings and a different hub setup. You could always swap to one of those axles. That's something I'd like to do someday when I have nothing better to work on. The 01+ trucks also had larger front brakes.
