trouble with my 95 ram 1500
Old Dec 11, 2013 | 08:29 PM
bjill462's Avatar
bjill462
Default trouble with my 95 ram 1500
hello, i am getting codes 43,42,47, and 21 from dodge ram. it starts right up when it runs for a while it will stall and take almost and hour before it will run again. it turns over but wont fire. i am not sure what to check or go from here. can any one please help? thanks guys
Old Dec 12, 2013 | 11:23 AM
21 O2S Stays at center O2S shorted to voltage
42 Open or short in the ASD relay wiring or connectors.
43 Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time.
47 Charging system voltage too low.
An interesting set of problems, which could all be related to the charging system. That is the first one that needs fixed.
Probably just time for a new O2 sensor though.
Fixed your plenum yet?
Welcome to DF!
