Whining noise while accelerating
Old Dec 15, 2013 | 04:49 PM
JYost1987's Avatar
JYost1987
Default Whining noise while accelerating
My 95 ram 1500 4wd makes a loud whining noise when I press on the gas. My four wheel drive won't engage either. What could this be?
Old Dec 15, 2013 | 08:07 PM
Does it whine in neutral? If it does, open the hood, reach in and crack the throttle a bit, and see what you hear. Probably a bearing on a pulley, or water pump.... (or, low on power steering fluid.)
Check for vacuum at the CAD on the passenger side of the front axle. Should be vacuum at the outboard port in 2wd, inboard port in 4wd.
Old Dec 16, 2013 | 07:09 AM
JYost1987's Avatar
JYost1987
It only whines when I'm driving down the road. It sounds like it would if I was driving in reverse. Torque converter maybe? If that was the case, wouldn't I notice some power issues?
Old Dec 16, 2013 | 07:32 AM
JYost1987's Avatar
JYost1987
The whine seems to be in sync with the accelerator pedal. If I let off of it and cruise I can still here it but it's very faint.
Old Dec 16, 2013 | 07:42 AM
JYost1987's Avatar
JYost1987
I know that this is going to sound ridiculous to you guys but, what is the cad? I'm not a complete moron when it comes to vehicles but I don't have a lot of experience with trucks.
Old Dec 16, 2013 | 09:48 AM
Ram Driver's Avatar
Ram Driver
It sounds like you might have a bad pinion bearing in the rear axle, maybe. I had this same problem with the same symptoms you describe on another vehicle I used to own.
