Plenum gasket Manifold replacement
Old Dec 20, 2013 | 01:30 AM
James Dorman's Avatar
James Dorman
Default Plenum gasket Manifold replacement
I've heard about just replacing the intake with the airgap/mopar m1 yet they cost around $300 each.. I found this link and a couple others for this one only $160 dollars, and was wondering if it would fit?
http://www.ebay.com/itm/Mopar-Chrysler-Dodge-SB-318-340-360-Eliminator-Intake-Manifold-Satin-/201006417123?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eccea84e3
Old Dec 20, 2013 | 05:28 AM
James Dorman
Did some research on it, has an air gap, and it says that it will fit the late magnums too, so i might throw this on and try it out.. Will I need any type of adapter for the TB?
Old Dec 20, 2013 | 05:39 AM
Matt Nickerson's Avatar
Matt Nickerson
What year truck do you have? That intake is for carbureted engines and won't work on 2nd gens. And m1 or air gap intakes are not $300..they're more near $600 with gaskets and bolts included.
Old Dec 20, 2013 | 07:53 AM
dhvaughan's Avatar
dhvaughan
the difference between one for a carb and a magnum are the 8 fuel injector holes out the sides. (and the extra $450).
if you're interested watch ebay, sometimes you can get one for $300 or so if nobody else is wanting it more than you.
Old Dec 20, 2013 | 11:56 PM
James Dorman
I have a 1996, and damn I thought I found a good deal. Summit racing has some of the Mopar m1's for around 300 I think.. Might just end up doing the kegger mod, and get the hughs replacement
