2000 1500 Brake Rotor Replacement
Old Dec 20, 2013 | 03:55 PM
ThomasF's Avatar
ThomasF
Default 2000 1500 Brake Rotor Replacement
Do I have to remove the axle nut on the 2000 to replace the brake rotors? I have read conflicting information.
I guess there was a brake change at some point around the 2000 models.
Also, what rotors have been used with success?
Thanks!
Old Dec 20, 2013 | 04:01 PM
ThomasF's Avatar
ThomasF
Guess this should maybe be moved into the tech section!
Whoops!
Old Dec 20, 2013 | 04:44 PM
Ham Bone's Avatar
Ham Bone
Pretty sure ya don't
Old Dec 20, 2013 | 10:50 PM
Silconcer's Avatar
Silconcer
Well a sure fire way to find out is take the wheel off. Take some pressure off the caliper and if you can wobble the rotor back and forth you have to newer style hubs.
An easier way to tell is if you have a dust cover over the hub nut and its packed with grease you have the older hubs.
