dodge ram 1740
Old Oct 8, 2005 | 08:57 PM
oneball's Avatar
oneball
Default dodge ram 1740
Hay guys and gals
can someone tell me what is the deal with fault code 1740.. My 2001 dodge ram a week ago set this fault and I started to go to the net to find out what it's about. No one can tell what really is causing it I went to the dealer and got a presure restricter plate with a bigger hole the size of a tooth pick but i can't tell were it goes. I work for a BMW dealer and those at this point are not as big of of a pain as this truck is...
Old Oct 9, 2005 | 05:34 AM
Ramtuff's Avatar
Ramtuff
Default RE: dodge ram 1740
Is your tranny acting up? P1740 is the torque convertor clutch or overdrive solenoid.
Old Oct 10, 2005 | 12:24 PM
2001ramsport's Avatar
2001ramsport
There are several resons for the p1740 code .I had the same code last winter,took it to the dealer and they did a stall test on the t. converter.Found the T.C. was bad(very common with dodge). Changed it myself with one from Level 10,been fine ever sence.
Old Oct 11, 2005 | 11:16 PM
oneball's Avatar
oneball
thanks for the tip have not had any tranny problems. Seems to run fine.
