Throttle Position Sensor TPS
Old Dec 30, 2013 | 12:31 PM
hinsolar57's Avatar
hinsolar57
Default Throttle Position Sensor TPS
Hi I'm new to the forum I recently purchased a 1998 Dodge ram Cummins Diesel N6 and have learned alot about this truck it is a salvage truck, it has a 1998 chassis but the rest of the truck is a 1999 Ram 2500, it has a fuel tank of a 1500 Ram. I'm making the best of this truck as I go. The dealer was selling it for 8000.00 but my wife & I got it for 3500.00 put a new computer and transmission relay in it and the truck ran fine, but the we started having other problems arise, I replaced the speed sensor, and then another problem. I don't even know if the external plug to the glow-plugs even work, I'm having a major problem with truck running down the road and the truck slips in & out of OD and the RPM's going back and forth and even drops out to zero, but pops back up to position. I have read in two different manuals to check the TPS for the problem, I was told you can clean the contacts and reprogram the unit. But I don't know what to do or where to start, this truck is now my project truck to restore the broken items on it. I love the truck just need some guidance on what to do. Please help!
Welcome to DF. Moving to the correct technical section.
