still no power
Old Jan 3, 2014 | 11:02 PM
ok, guess that's not it.....
Have you check to see if you have a dragging brake? Smell anything odd after driving it for a bit?
Old Jan 4, 2014 | 07:44 AM
dieselsuburban95's Avatar
dieselsuburban95
I dont smell anything other than coolent yesterday that I spilled
Old Jan 4, 2014 | 09:30 AM
Run the compression test. See what the numbers say.
Old Jan 4, 2014 | 07:00 PM
dieselsuburban95
Ok ill run the test whene I get time I was playing with it earlier and turned the od off and it seemed to run better had more power from take off all the way up but I also noticed that I have more power at hiway speed like when I want to pass I step on it and it goes any suggestions
Old Jan 4, 2014 | 09:52 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Do as Merc & HeyYou have asked and do a compression test. We really can't give too much more advice without that.
Are you saying you felt more power when stepping on the gas pedal when you were driving with the OD off?
Old Jan 4, 2014 | 10:51 PM
dieselsuburban95
Yea it didnt have to unlock the converter
Old Jan 4, 2014 | 10:52 PM
Converter still locks in third gear, but, disabling overdrive also changes the shift points.......
Old Jan 5, 2014 | 02:12 AM
ReadRam's Avatar
ReadRam
Yeh it's going to feel more responsive since your already locked in 3rd with OD off.
Old Jan 5, 2014 | 07:30 AM
dieselsuburban95
Ok then thats that
