CAD on front axle
Old Jan 4, 2014 | 10:41 AM
aofarrell2's Avatar
aofarrell2
Default CAD on front axle
Okay, so the Dodge is back on duty again (kinda, gotta fix my accelerator cable permanently before it hits the highway)! More power than ever... Many of my problems were caused by a faulty ignition module... Any rate, not what this post was about...
My engine doesn't generate enough vacuum to move the CAD. I'm planning to do a DIY PosiLok kit, but until then I've heard you can permanently lock the CAD in the engaged position. Any pics of doing this?
Old Jan 4, 2014 | 11:31 AM
Ham Bone's Avatar
Ham Bone
I'm not sure how but, if you could get it to lock you could then disconnect your vacuum lines and put your t case in neutral. That would let you still drive around in 2wd until you needed 4x4
Old Jan 4, 2014 | 12:49 PM
Don't get enough vacuum? Think I would try and figure out just why that is. Might be as simple as a leak somewhere....
Other than that... you can pull the cad cover off, pull the e-clips that hold the fork in place, slide the ford into the engaged position, and reinstall the e-clips to hold it there. Slide the collar over so the axles are locked together, reinstall cad cover, making sure fork will hold the collar in place. Don't bother hooking up the vacuum lines, just plug 'em off.
Old Jan 4, 2014 | 01:12 PM
aofarrell2's Avatar
aofarrell2
No vacuum leaks... Lol, I've checked...
Wow HY, best instructions on how to do it that I've found yet
