where is the fuel pump reley??
Old Jan 4, 2014 | 10:49 AM
pipeking's Avatar
pipeking
Default where is the fuel pump reley??
how has it been everyone, happy new year. got my truck back and well it's broke of course. pretty sure the fuel pump is shot, cuz I don't have any pressure at the test port. so I want to troubleshoot b4 I pull the pump, but I can't find the a relay specifically for the fuel pump.
Old Jan 4, 2014 | 12:38 PM
ReadRam's Avatar
ReadRam
The relay is in power distribution box (PDC) just south of battery if your facing north. Trans, horn, a/c relays and bunch of assorted fuses in their. Swap with horn relay is a easy check.
Old Jan 4, 2014 | 06:17 PM
pipeking's Avatar
pipeking
so I jump out the fuel pump through the relay outlet, I put 12v to socket 5/87 from 12v constant socket 3/30 using a multimeter set on 10amp load, and nothing. I did disconnect the neg batt and also put the multimeter (10amp load) on that to make sure it was working. I thought maybe I would get a high amp reading on the multimeter if the pump motor was locked, but I got nothing. so is that how u u would do it and do I have to replace the pump?
I kind of hope its as "easy" as just replacing the pump
Old Jan 4, 2014 | 06:20 PM
Don't think you can use the multimeter as a pass-thru device...... (but, I have been wrong before.)
Are you getting 12 volts TO the socket?
Old Jan 4, 2014 | 06:49 PM
pipeking's Avatar
pipeking
my multimeter has a 10a circuit for testing load. so if I disconnect the neg on my batt then use the multimeter to connect the batt - to the trucks neg wire it will power on the truck and tell me the amps that the truck is drawing. at the very least I should have gotten a reading if the pump was drawing power.
p.s. I did use a jumper wire and a gauge on my fuel rail to see if it kicked on, but I thought the amp meter would be "more better". And my relay is clicking when I plug + unplug it.
Old Jan 4, 2014 | 06:53 PM
If the pump didn't run with a jumper wire either, need to verify you are getting 12 volts TO the relay. The main feed should be hot at all times. (pin 30) If not, check fuse 3 in the PDC. (20 amp)
Old Jan 4, 2014 | 07:19 PM
pipeking's Avatar
pipeking
of course, I have consent 12.5v at pin 30, and I get 12.4 at pin 85 with key on (0 with it off).
Old Jan 4, 2014 | 09:02 PM
pipeking's Avatar
pipeking
Making new post. Relay found> thanks
