I lost power to my radio please help
I have a '01 Dodge Ram 1500 truck, I installed a JVC Am/Fm Cd player when I bought the truck. Everything has been fine for four years. I decided to put in a Pioneer Cd Am/Fm player. During this process I got no power to the Pioneer so I decided to re-hook up the JVC and I have no power to the JVC. I also, have no interior light, no cargo light, and no under hood light. I check all of the fuses several times and they are all good. All other electronics seem to work. I also have a super chip re-programer/diagnostics check computer and it also will not get any power when I plug it in. Can anyone please help me with this problem? TIA
Check your 12V switched wire coming out of your ignition switch with a test light. I've been having problems lately with wires breaking right at the multi-function switch connector, and the ign. switch connector. I know you said you checked the fuses, but try changing it out anyway. Hope this helps.
IT will be a differnt fuse than a radio fuse, weird i know, check ALL your fuses... use a test light ifyou wanna get a good fast reading... take teh test light and ground the alligator clip,then, touch the endof teh fuse,where you can see the metasl of each prong, touch both sides to make sure they light up, if both sides dont make the light come on, ya found it, can check a big fuse panel realtivly fast and accuratly like that...
anytime i may think its a fuse... i dont even check it... i replace it... things are so tiny and cheep... ya never know how crappy they can be made... and check the harness's that connect to your fuze block too.. i like matches
