failed emissions: where to start, what to check?
Old 01-08-2014 | 07:43 AM
Man you can get the whole converter assembly with pipes for @$200 on ebay.
http://www.ebay.com/itm/Dodge-Ram-15...#ht_1315wt_783
Direct fir from Summit without pipes for @$100
http://www.summitracing.com/parts/ct...model/ram-1500
Any of those from rock auto will fit, but there are cheaper ones out there. Google is your friend.
Old 01-30-2014 | 01:15 AM
corona4's Avatar
corona4
wanted to thank you guys for the help.
got a direct fit one for $200 shipped. unbolted and cut the old one out....couple u clamps, new one in, and passed emissions easily.
no more check engine light. i've only gotten 12.6mpg the last 2 tanks though. down 1mpg from my typical average. figured unclogging the exhaust would have helped the efficiency a bit, not hurt it. strange
and unfortunately right before fixing the cat i blew a front u-joint out that set me back $350 (axle couldnt be salvaged), plus a day of work to find the part locally and swap it out. ugh. life goes on.
Old 01-30-2014 | 08:10 AM
Annihilator_X9's Avatar
Annihilator_X9
The new cat is probably being more restrictive which be would why your other one was failing emissions testing.
Quick Reply: failed emissions: where to start, what to check?
