Dual HID Issue
Old Jan 9, 2014 | 08:32 PM
emattern06's Avatar
emattern06
Default Dual HID Issue
Ok so i've already searched the forum on this issue and can't find a solution. I have a 2001 Sport with a Bi-Beam HID harness with relay kit paired with aftermarket single bulb headlight housings. Now it seams to me as if the low and high beam positions are switched. The low beams look like highs and when i put i the high beams they point toward the ground as if they are supposed to be lows. Now I don't know if this is because i need the Spec-D projector harness for the sport model or if its because the harness came with backwards wiring. The harness I have is for the 9007/HB5 bulbs. Can anyone shed some light? Thanks.
Old Jan 9, 2014 | 09:32 PM
emattern06's Avatar
emattern06
problem sloved
Old Jan 9, 2014 | 09:44 PM
What was the issue?
Old Jan 10, 2014 | 09:02 AM
emattern06's Avatar
emattern06
Pulled some wiring diagrams and the HID harness had the low and high beam wires switched. So I just used a pick uncliped them and swaped positions
Old Jan 10, 2014 | 09:43 AM
That seems to be standard behavior for the aftermarket companies. I have been seeing threads of this nature since I joined here. The companies MUST be aware of it, yet nothing changes. Curious.
Old Jan 10, 2014 | 12:24 PM
emattern06's Avatar
emattern06
Lol yeah you think they would but apparently not. Oh well I'm just glad it's fixed now
