30,000 miles on Champions
Old Jan 12, 2014 | 09:11 AM
charlie1935's Avatar
charlie1935
Default 30,000 miles on Champions
Started skipping around at idle.
Checked and had 30,000 miles on my plugs.
Put in a set of NGK FR4 (5155).
After over 60 years of using primarily Champions thought I'd try NGK.
Old Jan 12, 2014 | 09:38 AM
Copper core is usually good for around 30k anyway.
Old Jan 12, 2014 | 09:42 AM
charlie1935
Tried to post photos but didn't work.
That's longest I've ever ran a set of plugs.
Old Jan 12, 2014 | 07:28 PM
utahjd1's Avatar
utahjd1
I just changed my Champions. 50,000 on them
Old Jan 13, 2014 | 12:50 AM
charlie1935
On mine the gap had grown from .035 to over .040.
Old Jan 22, 2014 | 03:03 PM
charlie1935
Just an update.
I had a occasionally rough idle and then it started idling around 1500 RPM or a little more and check engine light came on.
Code reader said multi misfires & No. 6 misfire, high idle.
Plugs took care of the misfire but not the idle speed.
Replaced the lifetime AIC Auto-Zone valve with an Borg-Warner one. All is well so far.
Didn't check for blown plenum gasket but uses about 1/4 of an inch of oil on the dipstick in 8000+ miles.
