5.2 engine change out
Old Jan 14, 2014 | 04:37 PM
fubar's Avatar
fubar
Default 5.2 engine change out
I have a 97 Dodge Ram 1500 5.2 automatic 46re. The engine needs replaced so I went to the junk yard and bought a 5.2 out of a 97 Dakota with a 5 speed. Will my flex plate bolt up to the Dakota motor? Also I noticed a differance in the oil pan should I change out the oil pan and pickup? It appears the Ram oil pan allows more room to get the dust cover bolts out.
Old Jan 14, 2014 | 05:10 PM
AtomicDog's Avatar
AtomicDog
Yes, the flex plate will bolt on just fine. I would also swap the oil pan and purchase a new pickup. Before you install the used motor, I would also install a new double roller chain set, water pump, thermostat, freeze plugs, plenum gasket and distributor cap+rotor.
Old Jan 14, 2014 | 07:34 PM
moe7404's Avatar
moe7404
AH BRASS frieze plugs!!!! and plug the air vent in the cap with JB-weld.
Old Jan 14, 2014 | 08:14 PM
fubar's Avatar
fubar
Thanks for the reply Atomic Dog I agree replacing the parts now is easier than later. I'm thinking oil pump and maybe pull a rod cap to see what it looks like. Well Im off to the parts store. Thanks again
Old Jan 14, 2014 | 09:05 PM
AtomicDog's Avatar
AtomicDog
I went through a 5.9 engine swap with my truck a couple of years ago and I used a '98 Dakota 5.9 as the donor motor. I also installed a high volume oil pump and new pickup, too. I pulled the heads and had a valve job and new valve seals installed. Doing the plenum gasket and aluminum plate now will save you from having to do it later. I also used brass deep cup freeze plugs - all engine block plugs are 1-5/8" and the 4 cylinder heads plugs are 1-1/4".
Old Jan 14, 2014 | 09:07 PM
Isn't there a smaller one on the back of the block as well?
Old Jan 15, 2014 | 09:42 AM
AtomicDog's Avatar
AtomicDog
As I recall, all of the freeze plugs on the back (and front) of the block are 1-5/8". Not sure what the size of the cam plug is, as I rarely touch them.
