Checked your V10 harmonic balancer lately?
Old Sep 20, 2015 | 10:29 AM
Radram's Avatar
Radram
Thanks Hey You
Old Oct 15, 2019 | 02:11 PM
derek.tristate's Avatar
derek.tristate
I had a harmonic balancer installed at a Dodge dealership and it flew off the crank 6 months later is that normal? The truck does have 230000
Old Oct 15, 2019 | 02:57 PM
Nope. Not normal. Apparently, they didn't properly torque it.
Old Oct 15, 2019 | 02:59 PM
derek.tristate
They said it was torqued and I watched them torque it but never thought about rechecking it.
Old Oct 15, 2019 | 03:01 PM
If there as some dirt, or any other contaminates in there, it may have torqued to spec, then the contaminates wash out, and it's loose.....
Old Oct 15, 2019 | 03:03 PM
derek.tristate
Ya that makes sense. How often should you check the torque?
Old Oct 15, 2019 | 03:05 PM
If it is properly installed, you shouldn't ever have to worry about it.....
Old Feb 6, 2025 | 05:35 PM
92GYPSYB250's Avatar
92GYPSYB250
Originally Posted by dodgeramtexas94
I know this is not a new topic but it is a topic that should be kept on top of for the newer members or somebody looking for a answer. My 94 V10 2500 Ram 4x4 Auto finally decided to part ways with its old balancer. First I heard that good ole hard to find weird squeaky noise that seemed like a bad accessory somewhere or bad idoler but it is none the less than a harmonic balancer gone wrong. For those who don't know ... On V10's the room was tight with such a long engine so the engineers made the other surface of the balancer the pulley itself. This mean no pulley on the front that is normally bolted to the center on the balancer where it is solid mounted to the crankshaft. Being it is on the outside it is constantly being torqued by the accessories and putting stress and strain on the rubber that is supposed to be dampening the vibrations. Good or bad idea it is what we V10 owners have to contend with!!
The rubber gets aged and stressed and it slips out of place leaving it misaligned and out of balance or comes flying completely off. Mine threw the belt and slid back towards the timing cover. No more squeal sounds.
I saw in a old thread people asking where and what is the harmonic balancer. It is the piece attached to the end of the crankshaft on the front of the engine. It does not have a keyway made it in like most engines do. It is a tapered shaft and relies on the strong torque of the bolt and washer that holds on the keep it in place and not slip on the crankshaft causing major damage. That is the second problem with this design is so many v10's has a issue with the bolt backing off and allow the harmonic balancer to slip. It needs to be torqued to 130 ft pounds but be sure and check your manual for the exact amount for your V10 year. Pulling it off usually involves removing the radiator, taking out the center retaining bolt and then using a puller to grab the three places cast into the balancer to remove it. Sometimes there is other ways but DO NOT BEAT ON YOUR BALANCER or pry against the front cover. Damage will occur! When installing your new balancer be sure and put locktite on the bolt and torque it down to specs. Under torquing will cause regrets! To be sure it stays tight and have peace of mind come back and recheck it after you run it a couple of days and then check it again in a few thousand miles.
Does anyone know the specific size of the harmonic balancer center bolt? It’s definitely bigger than a 24mm lol
Old Feb 6, 2025 | 05:46 PM
Keith_L's Avatar
Keith_L
Most stuff on the V8s is legacy = fractional. Now, being that the V10 was a bit newer I don't know if they designed it with metric. I've done several 360s and I thought they were 1-1/8" for the crank bolt.
If I'm right that'd put ya at a weak 29mm.
Or maybe it's 1-1/4" which is darn near 32mm
Old Feb 7, 2025 | 09:22 AM
Keith_L's Avatar
Keith_L
Quoting myself for clarity, the V8s are 1-1/4". You should be able to get away with 32mm and one person said they used 31mm (it would have to be a sloppy 31mm).
I was still unable to find if the V10 uses the same crankshaft bolt, though.
I'm kinda curious myself and I do have a '98 V10 I service which lives just a few miles down the road, so maybe I'll get to check soon
